lights question
idiburner
Oconomowoc wi
hey everyone i just finished wiring up my goose-neck trailer. but a problem when i turn on the turn signals like the left one is blinks at a different rate then the truck and it causes the right turn signal to dim and re-brighten like it was flashing but its not and its the same when the right turn signal is on but the left is dimming. is that a bad trailer or truck socket? bad wiring? the wiring i used is just normal 4 color 4 pin wiring but i just split it and ran it since i had a whole role of it. could it be a bad ground? any help be much thankful as i got to pull it today.
sjwelds
Central KS
Well usually I've found on weird deals like that it is often times ground related.
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
Ground issue 75% of the time. Get a multimeter, set it on continuity mode, and check every connection to see if it's properly grounded (if it should be) or properly connected to the truck circuit.
