Zion
Truck in question:
Powertrain - 1994 7.3IDIT
Body - 1989 F250 Lariat XLT ECLB (Gasser)
Drivetrain - ZF5 w/ 4X4, 4.10 rear and corresponding Dana 60 Kingpin front.
Swap Truck:
Powertrain - 400
Body - 1981 F350 Ranger SCLB
Drivetrain - BW T-18 w/ 4X4, 4.10 rear and corresponding TB front.
I originally nicknamed my truck “Brass” because of the color scheme, but it is now officially “The Challenger” as it shakes and then self-destructs.
Since my last post, I took my first real dive into the engine and cleaned the top-side components, replaced the valley pan, valve cover gaskets, viton o-rings on all injectors, re-sealed the turbo, and was lucky enough to find a complete air filter housing so I could incorporate a CDR. From what I can see, it is still leaking oil from the hot side of the turbo and from one bolt on each valve cover (I didn’t know about flipping the washers at the time). I changed the oil, added Lucas stabilizer, and got an FL1995 oil filter. After priming the system and firing it up, the truck was performing well.
Now comes the tomfoolery. I was hauling a truck two days ago on a pretty rough highway and experienced some death wobble. Since I had already replaced the shackles and bushing that caused the original death wobble when I first got it, I chalked it up to the poor road quality and growing pains from not pulling anything for so long. Regardless, I took it easy on the suspension and finished the haul. Upon unloading the project truck, my IDI wouldn’t start without a jump-pack. With batteries and alternator less than a year old, I assumed it was bad cables or some kind of parasitic drain. After dropping off the trailer and heading home, I had two more instances of death wobble, this time much more severe. I was fortunate enough to have a Good Samaritan follow me with their hazards on so I could limp it back to the farm. I looked it over that night and a seal blew on the 4.10. That leads me to think it was a smoked bearing that passed away after receiving a load. This morning I tried to start it up to limp it to a shop and neither the starter nor GPs had enough juice to do anything. Looks like one of the batteries ruptured during all the racket.
I had originally set aside $1000-$1500 to make repairs and get the wiring sorted out before the IDI broke down. With these new issues, I’m not sure if I’m economically prepared to get the necessary repairs without sacrificing other important jobs (such as functioning gauges and dependable electric system). I have a hunch that the 89’s drivetrain and body are going to nickle-and-dime me to death, which leads me to seek some advice. I can either continue with my original plan of making repairs on the 89’ and bite the bullet on what gets skipped, or swap the engine and transmission into an 81’ F350 Ranger I have sitting around. My grandfather bought it brand new in 1981, and its survived 35+ years of abuse on the farm with no major failures (aside from rabbits eating wiring and my dad forgetting to put coolant in it, leading to some sporadic top-end knock). I’ve already got a shop that would happily do the work that is very familiar with IDI’s. Seeing that I could part out the 89’ and a 96’ 460 that I have, I think I could remain on budget and still complete the swap. The big obstacle is that I’m still pretty green when it comes to automotive and have no experience to draw off to help in deciding what is best. I’d greatly appreciate any advice you guys may have in terms of choosing between sticking with the 89’ or doing the 81’ swap given my current predicament.
Swap Truck:
Powertrain - 400
