I took the oil cap off with the engine running today to check for blowby. There was NOTHING coming out.
Eric
You gotta realize where the blow-by normally goes.
On the back of the intake manifold, there is a hole. The blowby is sucked up outa the crank area via the valley pan, through the CDR valve(big canister bolted onto the back of the intake) and into the intake manifold.
If you pull off the oil fill cap, the blow-by is still being sucked into the manifold via the valley, so in order to see how much blow-by there really is, you need to remove the CDR valve(only held on by 2 bolts on the back of the intake) and plug the hole in the valley, so the blow-by is now being pushed up/out of the oil fill hole.
The engine needs to be at operating temp, and you'll likely see more blow-by at idle than at higher rpm.
Zigg
