Just got a 1997 PSD ... A few questions
dieseldirt
Vermont
Go into the tech articles and read the 10k mod.might be all youre looking for since its a dump and you dont plan on any fuel upgrades.costs a dollar
.modded idm will also help,if you dont know how to solder,dont mess with your idm.myself and maybe a couple other guys here can do it for you.
Could not find the 10k mod. What is the scoop. Thanks
94f450sd
somewhere,ma
Dash gauges work the same as they always did.dash gauges are fine.pcm has its own sensors for engine vitals.you only need egt,trans temp,and boost.pcm only reads boost,still need to drill and tap exhaust for thermocouple, and need trans sensor with programmer or guages.
94f450sd
somewhere,ma
Since youre here.you should check out our sister site, www.superdutydiesel.com
Go to radio shack and get a pack of 10k ohm resistors.on the front of drivers side head behind the ac compressoris the ICP sensor,3wire plug,unplug it.look at the end of the plug,looks like 2 eyes and a nose.put the resistor between the nose and an eye.bend the resistor wires so they dont touch,plug it in.fire it up.if no start or check engine light with rough idle.unplug and swap the eye.fire it up.should run normal,may sound a little differen. CEL may pop on once in while if youre out
playing with it. Its ok shut it off and start it back up.
Fuel mileage will actually drop for about a month till youre done playing with your new found power.
MadScientist
