Fordsandguns
Fords Rule
First a little history here. A while back I started having an intermittent knock or pecking sound. I don't have a stethoscope so I used a piece of 3/4" pvc to try to pinpoint it. Never could find it. The loudest point was in the exhaust crossover.
I pulled the valve covers and looked for anything obviously wrong and found a loose rocker on the second cylinder from the front on the drivers side.
I talked with towcat on the phone and he suggested running a dose of auto rx. Well, I'm unemployed right now and didn't want to spend the money and my dad was after me to use something called engine restore. I wasn't about to put that in my engine so I compromised and used marvel mystery oil.
At about that same time I had changed my ip to a spare kind of as an experiment. Anyway the noise quit so I was thinking that it was just a sticky lifter. So I pulled the cover and the rocker was tight.
Well, now it's back.
I just did an oil change and when I emptied the catch can I found pieces of plastic in the bottom and I know the can was clean because I had cleaned it prior to starting the oil change.
I would have pics but I accidentally threw the pieces out with the paper towel they were on.
I tried finding that towel, but no dice.
From the size and shape of some of the larger pieces I'm thinking these were what's left of the valve stem seals.
Unless there are other plastic parts used in these engines?
I'm sure that it's time to pull the heads and do some repairs. Just what I need, even more money to spend.
Any advice or opinions?
Sorry for the long post but I figured you needed the whole story.
