HammerDown
S.O.A.B for the second time, the right turn signal 'hold' clip broke...and of course that little piece only comes with the wire harness running down the steering column $$$$$$$$$
S.O.A.B for the second time, the right turn signal 'hold' clip broke...and of course that little piece only comes with the wire harness running down the steering column $$$$$$$$$![]()
I know how the repair is done, as I did it beforeun pin the plug send wires up and then re pin plug once wires are feed back threw did it on a bronco about a month ago
No f'ing way, that would be GREAT...do you have a part number???On mine the white plastic piece is for sale thru Rock Auto and A/Z.
Some 10 years ago I remember being forced to pay Ford almost $100 because I had to buy the whole stinking wire pigtail...and unpin-repin each stinking wire end.
All that $$$ just to get the turn signal disk.
Well, yes, no and maybe...at 56, sometimes my time is more valuable then fixing broking sh*t on an old truck.Beats the crap out of monthly car payments on a vehicle while it depreciates in value.
BTW...to the fellas that dug out those "turn signal cam links" > > > THANK YOU!![]()
Many years ago I learned to use Moog...lifetime warranty.I hear you. Found both outer tie rod ends shot doing a tire rotation yesterday. They were fine less than 2000 miles ago.
At least they're cheap...
