It'a Always Something With These Old Trucks...
HammerDown
Glenolden Pa
I just replaced my turn signal switch with that same part. Make sure the screw at the 9 o clock position is turned down and the two light blue wires have clearance from the back of the wheel. After installing it I kept burning a fuse and didn't realize that the assembly was sticking out a few mm too far forward. The wheel and unbundling takes the longest but it's an otherwise straightforward task.
I just messed with it again...everything is seated etc but the top/right turn signal hook does not grab as should. Now if I remove the little centering leaf - spring then at times it barely hangs on.
I've wasted too much time messing with it and ordered the entire switch from Rock Auto.
However, I'll be a little more that disappointed if the new unit (right hook) barely grabs too.
vegas39
las vegas, nv
I tried to do the repair kit in mine a couple years back and that worked like crap. I ended up buying the new assembly from Autozone and all was well but I had to cut the big plug off the end and rewire it, it wouldnt fit down through the column as one piece.
HammerDown
Glenolden Pa
Installed the entire switch, wires and all part#SM66F (shee-Mar) and it works great > full 'hook engagement'...I just hope the darn thing lasts.
From Rock Auto called (oe-pro) to my door $38,00 and they credited my CC for $13 for the 'cam' that didn't work > way to go Rock Auto...you earned a new customer! ;Sweet
BTW...through Rock Auto this part has a 2-year warranty!
pwillis
