It was 83 the 6.9 was installed for the 84 year.
That's pretty cool. I don't remember hearing of or seeing a XLS model. I thought that the 3.8 was available for three years, but I may be wrong about that.
Lolol....I'm going to finish watching this later, right now I'm going to go look and see if I can find an "aerodynamic" part on my bullnose truck.....lolol...
Okay, I went back and watched the whole thing with my wife..... hauling the Dodge and Chebby up the hill was great....he should have done it in reverse blind folded yelling "NEENER NEENER NEENER!!!!!".....In my humble opinion.... and then yelled "DID CHEBBY TELL YOU THAT!?!?!" when he got to the top..... while throwing back some Goodies powders because he banged his head and his lower back was shot after that ride!
My dad had a 82 with a 3.8. it was a two tone powder blue with dark blue at the bottom and it had unique stripping that said "EXPLORER" in it. He drove it from Milton FL to Mobile AL every weekday for 2yrs when he worked at the ship yard over there. I helped him swap engines in it a couple times and I rebuilt the transmission in it. The body of that truck had about 500K miles on it and it went through 3-4 engines and 1 transmission..... when I see a bullnose Ford I think "that's my dad's truck".... thanks for sharing Goat!
Black dawg
sw mt
Had no idea they did the 3.8 in those. Been around so many, and the salvage yard we use to have had hundreds of those trucks, never saw a 3.8 in one.
Have seen an 82 with a 6.9 in it though. Pretty weird truck. Had mechanical clutch linkage with no spot on the bell for hydraulic. Pretty rare bellhousing, diesel pattern for mech linkage
Maybe a converted big block bell housing? Id say it had to be....
The only 3.8 I ever personally handled was the one in Dad's truck. My friend with the junkyard mentioned one a while back and said he'd never seen such, and thus confirmed that they made at least 2.....
Dad had an unfounded theory that the truck 3.8 was different from the car engines somehow, because the t bird engines that we replaced it with never had the umph as his first one......I doubt it, but Ole Dad had some ideas......I come by it natural if you wonder....
Black dawg
sw mt
The bellhousing is the weird part for sure. I had that truck apart, bell was un modified, aluminum and diesel bell pattern.mechanical linkage with no ears for the slave on the bellhousing.
I'm going to say it's from a different application then, like some sort of big IH truck......who knows.....Big Foot probably put it in deep in the woods of the PNW....
I saw one myself. It was being stripped out in a guy's driveway. This is the one that I though was a 1983 but I may be wrong.
That is strange. Maybe it was an early test vehicle that got away from the factory?
It's possible. As far as I know, the truck engines were the only 3.8s without CFI. All of the car 3.8s had aluminum heads, which doesn't say much since I've probably only seen 5 or 6. If the truck engines had cast heads, then they could have been different. Kind of like the GM 3.8s from the early/mid 80s were dogs as far as I'm concerned, but the GM 3800s were pretty good engines. No that doesn't include the 1986 Buick Grand National since it was a one of a kind car.
The funny thing about the cable clutch bell housing is that this was a 1982 with a 460, four speed, and a hydraulic clutch. Was it all original? I have no idea.
I said this because I met a guy who swore that he saw a 1993 with a 7.3 PSD in it. He said that it was all street legal, driven and everything. It could happen.
FrozenMerc
SW Missouri
It happens, not very often, but it does happen. Last year I was at one of our wholesale distributors up in Edmonton, Alberta of all places. He has a couple of V8 diesels sitting on a pallet, and asks us if we know what they are. Start looking them over, GM casting numbers and marks, but obviously the engines are built from prototype or pre-production parts. Did a little research, called some of our contacts at GM, and found out that they were 4.5L Duramax's. The link below has a bit of history on this canceled engine program. GM built enough of these engines to conduct durability, emissions, and other pre-production testing, but canceled the program before production could be started. GM should have destroyed all of the test engines, and hence, these engines should have never made it out into the wild. Granted, they were just fancy boat anchors without the ECU / Wiring harness, but there they sat, up in Northern Alberta, nearly 20 years after GM canceled the program.
https://www.enginebuildermag.com/2025/05/gms-4-5l-duramax-v8-that-never-was/#:~:text=The 4.5L Duramax V8,canceled before it reached production.
Black dawg
sw mt
I always thought it must have been some pre production test truck as well.
Also had an early 93 door date f250 with a 7.3 powerstroke in it that I worked on. Looked very clean and original, could have all been swapped in there I guess, but this was in 96 or 97, so probably unlikely.
u2slow
bilge rat
Coastal BC
.Kind of like the GM 3.8s from the early/mid 80s were dogs as far as I'm concerned, but the GM 3800s were pretty good engines. No that doesn't include the 1986 Buick Grand National since it was a one of a kind car.
There's a mixed bag of Chevy (229ci) and Buick (231ci) in the '3.8L' size of the 80's. The Chevy one grew to 4.3L by around 85-86.
I also remember that we had a 7.3PSD short block in our shop. It also must have been pre production because all of the threads were SAE instead of metric.
