rob93
Seems like fuel from everything will be able to make it way back to the tank... but will this be terribly inefficient?
I have a line connected to the fuel filter which connects to all the right side injectors then connects at the rear of the engine to the left side injectors which are all connected together but I cant remember if the IP is included in the loop on the left side injectors.
Also finally got her started back up after replacing the injectors and lines today. These damn things are finicky, I found a little leak from using a hose clamp and she was smoking out the neighborhood.
I ran out of the correct clamps and figured a hose clamp could work, I now see that it doesnt.
Any idea short of ordering online where I can find clamps of the style that go on our return lines? I'm not sure what they're called. Home depot and advance did not have them today, pepboys was closed, I will try them tomorrow.
If you dont have the correct size spring type clamp, a fuel injection type hose clamp will function properly without leaking. Worm gear clamps form a pinch on one side, but a fuel injection clamp encircles the hose and tightens evenly around it to prevent leaks in fuel lines. Any decent parts counterman will know what to get you
AZone carries the spring clamps, they come in different colors like, Green-Red-Blue for the different size rubber hose. If you have the normal injector kit for the 7.3 it would be 1/4" ID and would take the Red clamps IIRC.
Your fuel system is OK , but the return to tank at #8 should be orficed to maintain a low pressure in the injector lines. The return line to the filter helps the lift pump, meaning the LP doesn't have to pump as much fuel. The orfice should be about half the size of the fitting your useing. Normally there is a Brass TEE that is orficed to tank for crossover from #8 to #7.
