Black dawg
okay so a month ago I put a reman ip on my truck, trying to gain back some mpg, and fix an extended crank condition when cold. So truck then starts great, and mpg also better, but pump has problem with timing fluctuating at higher rpm. Pump shop gave me another pump under warranty that I am positive was the original pump that I took off in the first place. So put the pump on and mileage is still good, but I have an identical extended cranking condition when cold that I had in the first place. I am positive that air is not an issue, and have checked lift pump pressure. Glow system also functioning properly. Plugging in truck makes little difference and cranking speed is great. Am I wrong in thinking that the transfer pump could be weak and taking 6-7 sec to provide enough pressure in the pump? sorry this is so long and boring, but I am getting a little frustrated . the pump that started good was on for 2 weeks and truck started great with it every morning.
