dieselrunner
Problem is that, to fire my truck in the cold, I need to cycle the ignition (turn off then on again) a few times for the clow plugs to work properly. Now I know if there going to work by looking at the volt meter, and seeing what the power draw is.
Im assuming this is a ground/connection problem. So are there some connections or grounds that are common to have poor connections and I should check?
thanks.
thanks.
