input shaft
dodge_is_diesel
ok i have a very important question. im going to turn my truck up to about 530 rwh. obviously i will need to get a new clutch to handle that power seeing i still have a stock clutch. but, at 530 rwh do i need to upgrade my input shaft as well? im not sure if its strong enough to hold that power on my 5 speed. hopefully i dont have to get the new input shaft cause thats a lot more money then just the clutch. thanks guys
cummins superstar
cumberland wisconsin
the input shaft will be just fine at that kind of horse the only times i have heard of anyone breaking one is when they started using nitrous or running huge tires and being very stupid with the truck (redline then dropping the clutch it wasn't a pretty site) the bigger worry you should have is axles if you have a locker they tend to brake (replaced a few of them to):peelout
