The injection pump is a re manufactured pump from staydine . the injectors have 118k on them , don't know if they ever had been replaced before i got the truck . I read about the olives and return line is also probably a good idea , I like to eliminate problems before they happen . Where is a good place to order them ? Yea i read about unbolting the pump through the inspection hole in the front of the housing , I might have a little more work to be able to get to the hole, my truck is a dump and has the hydraulic pump on the front of the engine, and to mount it they made up a steel plate to mount it and it partially covers the access hole , so i may have to pull everything off the front of the motor .
