Identify this oil pump
Donwan
tx
old oil pump next to the new one I just got. What’s wrong with this picture?
bismic1
Texas
Ford428CJ
FE Freak!
Klamath Falls, Oregon
Bismic is correct on the years. The iron one is 2004.5 and on. I own a early 6.0 and it has the rounded guy LOL
I have had good luck Motorcraft pumps and BWD pumps myself.
Just be very cautious of the oil use! Shell Rotella T-4 is fine
Sent from my iPhone using Tapatalk Pro
bismic1
Texas
The iron one didn't make it into the 04.5's, just the 05 and up.
04.5 did get an upgraded pump to go along w/ the wavy oil rails, but it was still the "rounded guy".
Over on another forum, a guy just recently posted about his 03 engine HPOP experience. It failed at 200k miles (so not bad), but the new OEM pump he put in failed at less than a year. There are a number of posts about failures "out-of-the box". Probably not a great percentage when you look at the entire number of 03 and 04 engines out there, but the aftermarket has some better solutions. Corey at CNCFab sells an upgraded one that is cheaper than the Adrenaline and doing very well for reliability. He would be a good one to talk to.
Ford428CJ
FE Freak!
Back in 2011. My 03 HPOP took a dump. I bought an Reman Motorcraft Pump for it. Haven’t had a problem as of yet. Maybe knock on wood. Been doing very well.
Lately I have been changing out a lot of the newer style pumps with about 100,000 miles - 150,000 miles on them.
IDIBronco86
