I Got Stacks
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
Mine run through a box as well. It does have some muffling effect but so does a Y pipe. The box is the easiest and cheapest way to get around all the overpriced Y pipe and elbows. It is bolted down with springs on top like a wet line kit for a semi truck. This allows flex while holding securely. The box is also the cleanest looking way to mount them.
can you post a pic of what this looks like?
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
i think this is what theyer talkin about
IH_444
Iowa
Yeah, that's it. I'm going to make mine after I replace the leaf spring hangers (So the box can stay on for good)
Diezel_Cowboy
It's not like a real ***!
A little place called "nun a ya binez!"
I dont currently have a good picture of the real thing although if you look close you can get the idea. The other pic is a drawing I made to give to the guy who built my bed.
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
so basically the exhaust runs up to the box and then flows through there to the stacks? that sounds simple enough
