One thing not fully covered in the vacuum to hydroboost conversion is the cruise control hook up.
On the vacuum system, the master cylinder has a little plug with three wires coming out of it. I'm assuming this is the brake cruise control disconnect harness.
Well, the hydroboost has no such fitting, but just behind the hydro's reservoir is a socket with two large prongs in it. I'm assuming this is for cruise disconnect, however, have no clue. The hydro came out of the same year model as my existing truck, just a 450. Is there a special plug that goes into that socket or is there a different way to hook up the cruise control disconnect?? Does anyone have the part number for the plug that hooks into the socket?
If it isn't the cruise.... then what the freak is it?!!!
