how do I find out what my gear ratio is?
fez
Markleville, IN
this mind sound like a dumb question but how do I find out what gear ratio I have?
Clayton
Ky
Look in the drivers side door jamb for the axle code then post it here.
Ididriver
Panama city beach
my dad use to put a chalk line on the driveshaft and counted how many times it rotated for every complete turn of the wheel
say it took just barlley over 4=4.10 gearing 3 and half would equal 3.55
always seemed to work ive never personally done it tho
93f250idi
strokin
cadiz ky
someone could of swaped gear ratios along the years. easiest way to tell is like said above. mark a line on the driveshaft and count the rotations.
fez
Markleville, IN
alright ill do the first one cause the guy i bought this from was the original owner and he was not one to change anything. and if i have to ill mark a line on the driveshaft and count the rotations. thanks
MIDNIGHT RIDER
This would be a good excuse to change out the rear-end lube.
Drain the rear-end, remove the cover, and rotate the ring-gear around until you come across some numbers stamped in it's edge.
Of course, equipped with these numbers, you can then do the math.
41:10 = 41 teeth on the ring and 10 teeth on the pinion; 41 divided by 10 = 4.1 or for our purposes 4.10
37:9 = 4.11
For what it's worth, although for all practical purposes the gearing is so close as to be considered the same, a 4.10 set of gears is immensely stronger than a set of 4.11s, due to that extra tooth on the pinion making the pinion head so much stronger; if you saw both side-by-side you could see what I mean.
I can't right off remember the tooth counts; but, there are also two separate gear-sets that provide either 3.54s or 3.55s and I can't remember just which of these two is the stronger. :)
lynch
little stinker
Harrisburg MO
i have a 94 f250 diesel and the axle code is 35 and they are 410s we just bought a 92 that has a axle code that is 45 and its 410s to. Go to google and type ford axle codes and there should be a site that will tell u all the codes and what gears they are.
