dyoung14
Is getting worn out
My girlfriends 89 needed return lines horribly as all were leaking all over then engine, and i cant afford a 50 dollar kit at the moment, now i always wonder why you would have to replace the plastic cap unless something was really wrong with them, so i bit the bullet went to my local napa and set down and dug thre the o-rings till i found the one that looked identical, bought 16 of them, bought enough fuel line to do the job and a couple hose clamps and a 3 way "T" to convert the old style return to the later style cause i like them better, and put it all together and i have no more air intrusion problems now and no fuel leaks
not saying this is the right way to do things, just that i only have about 11 dollars in this and it works great, and when money is tight anything that saves me 40 dollars is great
Just figrued i would share
