Worstenemy453
Well a few weeks ago my truck left me chillin on the side of the road. 2 belts broke, which in turn wrapped around the fan and while they were on the fan they yanked my trans cooler lines so i lost all my ATF and 2 belts. Luckily my powersteering went out when i lost my belts so i realized i had a problem and pulled over before all my ATF drained. almost 90% drained after i pulled over.
Anyways. Put all 4 new belts on at almost $100 total after discount on all 4. New ATF and all and everything is good.
Well now my powersteering pump seems like it might be slipping. It makes funny noises when the wheels go all the way one way or another, sometimes itll do it from normal driving and if the tire is touching something itll stop the tire from turning but i am almost certain the steering wheel keeps turning. Thats bad correct ?
Also, i turned the heater on last night cuz it was chilly. Turned it on mix, no air was coming in through the vents and i started smelling burning rubber, turned the heater off and no more smell. I cannot for the life of me remember if i turned my heater on when i lost the 2 belts. My heater and AC was working fine before. What could be the issue ?
