High speed miss with a 6.9
RDieselKid84
Mississippi
This is the problem I'm having it idiles fine but it misses @ 65/70 but not all the time, all help will be appreciated.
When it misses does it seem like it looses power then comes back in excess then goes back to normal?
Macrobb
North Idaho
If it's smoking white when doing so, It's probably the timing is very retarded. This is due to the IP & injectors being worn.
RDieselKid84
Mississippi
The power doesn't change it's just a miss miss and then it will quit and come back, It mite go for a few miles and do it again. There is no white smoke and I have the timing avanced a little. The IP has about 3000 miles on a rebuild and the injectors were cleaned and reset at 1800 psi.
Macrobb
North Idaho
It's definitely fuel. Might be an injector? Can you take a video and upload to Youtube?
RDieselKid84
Mississippi
I will try to get one it might be next week before I can do it and post it. Like I said when it misses it is a dead miss.
placidoert
