MandolinMan
Hello all,
I just purchased my first truck, a 1988 Ford F-250 with the 7.3 and a 5 speed manual. I was able to get a great deal on is because it has a starting issue (Which I hope isn't very serious). It has 197,000 miles on it, but appears to be pretty well taken care of. Here's the details:
When I turn the key halfway in the ignition the wait to start light comes on for a second or less then goes off and there is a clicking sound from under the hood. I hear that the WTS light normally stays on for 8-10 seconds?? And is the clicking normal?
The engine turns over fine but will not fire. However, with a shot of ether in the intake it usually fires right up. If it's been running for a while, it will usually fire up without the ether.
I bought it from a farmer who only used it occasionally and rather than fixing the problem just used the ether. He suggested that it was probably the glow plugs. Hoping you fellows could help me get this issue worked out. Thanks ahead.
