WHOA....hold on boys n girls......cut out many a windshiled.....I HATE wire!
First I am going to make the guess you want to pull one from your TRUCK?
If it is simple, but extremely difficult....ya I know makes no sense...
Simple cause you need a very good OLFA knife that holds the blade good n tight....LOTS N LOTS of blades...20 is a good start!
Or better yet One of those and this here too
Then a bottle of good soapy water lots n lots of dish soap making slippery water that won't harm anything
Remove outer trims and clips
remove all inner trims A pillars and forward headliner trim
On the outside of truck...cut along edge of glass down towards CAB cutting away all excess material and be carefull to not chip glass...then work that gunk out of the area so that there is no excess material left. Spray spray spray the ureathane with soapy water while cutting to lube the stuff so knife cuts it out nice and easy....
this makes cutting the windshield out a lot easier as your knife has less material to cut through.
Next on the inside of truck, spray around a top corner...lots n keep spray ready, start cutting with the knife from a corner down towards base of A pillar, you will need to make SLICES repeatedly in the same slice spraying to keep lubed and eventually you will cut through to outside...you will know when. Keep doing this technique around entire windshield and you can cut out windshield in about 25-35 minutes...
I suppose I can do a Pictutorial and maybe add video too...if requested, I will have to remove the windshield from my SC to replace it anyway, it's a prime candidate for doing such!
JM2CW ...done this lots n lots n lots...its easy but difficult cause yer arms ache when done from all the repeated slicing!
Al
