EMD_DRIVER
Say what?!?!
I was towing the 5er last evening and my boost started dropping and then coming back. It finally went down and wouldn't come back. I did not have the water injection system on at the time. I dropped the trailer and tried getting to the nearest parts store, because I thought the MAP sensor had gone out.
While trying to get there, the truck seemed to load up on fuel and couldn't make more than 3PSI of boost. If I tried going faster, it would start running VERY rough and stall. It almost sounded and felt like I lost an injector, but would start running and idling fine if I let it idle for a while.
I managed to limp the truck home and I'm now stuck here. A friend came and dropped a new MAP sensor off to me and went and picked up my 5er for me. When I put the new MAP sensor in, the truck started and ran great. It even got up to 15PSI of boost, when I was getting on the interstate. About 3/4 mile later, it started acting up again. Boost dropped, started missing on one cylinder and died on me again.
When the miss clears up, I can run the truck slow. If I try to go over 5PSI of boost, it starts missing and falls on it's face. It takes quite a while, before it will clear up.
I need some ideas, since I have to get my 5er back home on Monday. Please help!
