Help identify what's wrong with my ill 7.3 IDI
G codes are the turbo injectors. Any other code is a non turbo type injector. E was probably original to this engine.
Spun4Fun
NC
Thanks Gary .. I was going to try a
Set of BB code if I can find them since I have Banks turbo Or might stick with these E codes depends on the pop test result
Spun4Fun
NC
Had my injectors tested but Unfortunately total of 5 injectors failed spry pattern,4 passed on the pop pressure test around, the 5th one had popped at low pressure the 6th injector is border line, leaving 2 injectors in acceptable condition.
i came across a set of Delphi 6760301 should be BB code New will they perform well or should i stick to Stanadyne ?
sjwelds
Central KS
You've been around here long enough I'm sure you've read about Conestoga diesel, R&D, and typ4. I'd stick with known good quality if it was me.
Spun4Fun
NC
Absolutely that is the route I am taking with the injection pump
I was asking about the Injectors New Delphi BB to mate it with new IP
I have a new set of E code injectors and a Valley pan, don't remember if it's a Fel-Pro or Victor-Reinz. PM me if interested.
Sorry, there A code for the early 6.9., really expensive now, only rebuilt are available.
Spun4Fun
NC
Some members here using the Delphi BB code with great feedback, i just wanted to know who's still using them and what they think
MadScientist
