HELP AUTOLITE GLOWPLUG
idiburner
Oconomowoc wi
so cylinder 2 glowpulg had to be an autolite and had to brake how do you guys get those tips out off the piston i dont have time to remove heads? its a 7.3idi turbo
BDCarrillo
Abilene TX
If it hasn't fallen in, put a towel over it and crank the engine.
FordGuy100
Silverton, OR
You can try to vacuum it out of the injector hole, but it will be tricky. I dont remember the diameter of a glowplug tip, but perhaps you can buy a bore scope to help out (the smaller they are the more costly it seems, you can find them on ebay).
Good luck with whichever way you decide.
