I have been having a rotten month so far. It started out that the turbo drian bolts loosened and lost a bunch of oil every where. Ok easy fix. Then start it up later and ran for a minute shut it off and checked the oil. Nothing on the dipstick, then hear noise in radiator. Took cap off and probably 2 gallons of oil in coolant. Put a differant oil cooler on and thought all was well. Took it for a drive and ran perfect. Got home and took the radiator cap off and non stop bubbles are comming out of the radiator . Took the compression and the results are.
1-430
2-440
3-420
4-400
5-370
6-380
7-420
8-400
Could this be a headgasket or is this cavitation? The truck starts, idles, and runs like it awalys has. I have not seen any smoke other that the typical diesel smoke.
I am on my wits end trying to fix everything. Any and all help is much appreciated.
1-430
2-440
3-420
4-400
5-370
6-380
7-420
8-400
