Heim Joint clutch repair parts
Last Friday morning after work the ball joint/ tie rod end that the last owner of my truck fixed the clutch linkage with broke. Came to a stop sign pressed in the clutch and SNAP pedal on floor no clutch floated gears and got it home. Rigged it up to make it work for a few days until I could find parts. Got it together today with a nice heim joint WOW now that's a smooth clutch!! It actually feels much softer also.
I've read that floating gears with a zf-s5-42 is real bad. The sychronizers are a softer metal. I would say I know this from experience, but actually a pto box took out my whole trans. I'll get pics if you want.
On a sm465 I can float gears all day long. Even down into first for stop signs.
Now back to the heim joint, I'm sure you could make a few bucks on ebay with these.
asmith
Atascadero, Ca
This is the best picture I could get. Basically you cut the eye end off the shaft and thread it to put a joint on. I was going to make some up but there was no interest so I never made any.
that is a great picture!!;Sweet thank you so much. why is the heim joint better than the regular joint style? my rod has the hole all egged shaped now and i am looking to replace it. i would be interested in buying one from you if you want to make one. i do not have the ability to make one myself. can you install a new rod without pulling apart the dash? i am just starting to look into this project, so i am just trying to gather info. thanks!!
ADV
Wisconsin
The heim joint fix gives you a much smother feeling clutch it like a different truck when you do this. You do not have to pull any of the dash apart you just go under the.dash and remove the push rod. You will need a special tool to remove the push rod.
I have not made any push rods yet. The one in my truck is just a reworked stock push rod that is working just fine. If you are interested I have a few stock push rods I will rework one and ship it out to you. Then send me your junk one so I have a couple push rods.
I can do this as an exchange program. I will send out a reworked push rod that a heim joint will fit on to who ever needs one as long as they send me a factory push rod back and a little money for doing the work and shipping. I will also make up a push rod removal tool I will send along with the push rod
and you can send back to me when you ship me your push rod.
John
Dsl_Dog_Treat
Decatur,MI
You still have to get the tab off the clutch pedal to remove the pin that the push rod is attached to. It's NOT a bolt on application.
asmith
Atascadero, Ca
i am assuming you mean that little tab that is bolted to the heim in the picture? :dunno that looks fairly easy to take off and then drill it out to accept the bolt, correct?
ADV i would really love that. i just want to clarify a few things. this would NOT come with a heim, but would be ready for one to be screwed on. what would the price be? thanks for your help.
tke395
