Heavy carbon on #7 injector.
Darryl97420
Coos Bay, Oregon
Recently I had a problem with an injector partially melting and covered with carbon. When I bought a new injector to install, it wouldn't fit into the injector. My solution was to see if the injector would fit into cylinder 5 which it did then I put the old injector from 5 into 7.
Its time for new injectors and an IP.
Now move forward to today. I pulled the injectors and most were in good shape considering they were installed in 89. But the one injector from #7 was covered in carbon. Before I throw another injector in there, should I do anything? What about putting in a larger washer or maybe a second one to help with sealing out the carbon?
The rebuilt injection pump should be here tomorrow and I would like to get everything in order before I install it.
Thanks,
Darryl
flareside_thun
Reviving The General Tao
Tavares, Florida
Did you replace the fire washer when you replaced the #7 injector before? A bad fire washer seal is what causes the carbon to build up into the injector bore. Stacking 2 washers will only cause the problem again. Make sure you do your best to clean the injector bores with carb cleaner and a pipe cleaner. Any kind of leak will only cause future problems.
Darryl97420
Coos Bay, Oregon
Carb cleaner? How does that work, spray and scrub then blow it out by cranking the engine? I intent on stopping by the gun shop and grabbing some cleaning brushes to handle the scrubbing part and some SeaFoam spray for the carbon.
Once clean now do I make sure there is a good seal with the fire washers?
flareside_thun
Tavares, Florida
Yup, that's how I do it...find the torque specs for the injectors(I think It's 35 ft/lbs) or just get her goodntight, but don't over-tighten.
Sounds like you didn't replace the copper washer from the first injector replacement and maybe added a second one on top of the old damaged one. The ice pick will get the carbon moving. Once you remove the original copper washer drag the ice pick or a dental around the seat in the head. If it stops moving around the surface thats a cut from compression gas burning across the seat. You will need a seat cleaning tool to repair that.
Darryl97420
Coos Bay, Oregon
I do know that when I tried to put a new injector into #7, the injector would not seat however an old one did. But now that I am home I would like to make sure that I get a new injector in #7.
When I am done cleaning I will post a picture of the bore to see if there is anything I am missing.
Dsl_Dog_Treat
Decatur,MI
Using forced air into the GP hole will keep the chunks to a minimum.
Also, but wear eye protection when doing it.
Darryl97420
Coos Bay, Oregon
Would you believe that the valve cover was over just enough to prevent the new injector from going in? Once I loosed the cover just a bit and bumped it with my palm the injector dropped in.
All injectors are in. Thank you everyone for your help.
How I need to find a thread on swapping out the IP and how to manage the fuel lines.
