heater selector
flatlander
plays dirty when losing
ft. wayne IN
I cant get airflow from anywhere except the dash panel. How do I fix this so I can have air on the floor and defrost mode?
highest_vision
Reqistered User
Boone, North Carolina
Might have a door hung up or hinge broken. Should default to defrost/floor I believe with no vacuum applied, if that doesn't happen, will probably require some surgery :sorry:
James
John Deere
Wyoming
I just went through this problem on my '78, seems a mouse made a nest in my ducts, all I could get air out of was the A/C vents. I broke it all loose with compressed air, then let the fan blow it to the defrost vents,, where i had to keep removing the pieces. I still keep getting pieces coming out from time to time.
hesutton
The Anti-Anderson
Bowling Green, KY
I had a similar problem with both my trucks for two different reasons. On the project IDI truck, the hinges where sticking and one was cracked. Replaced the plastic hinges with metal ones, Pop-rivited on, no more problem.
On the gasser, there was a vaccum leak and it couldn't produce enough vaccum to open and close the door to redirect the flow of air.
Don't know if that helps you, but at least you know of a couple of places to start looking I guess.
Heath
