On my 86 6.9 the high beams work pretty good for what they are, but when I go to the dims they either flicker or don't work at all. What is the best way to fix this issue?
If you want to do the shotgun approach and just try replacing something, the most likely culprit is the dimmer switch in the floor. They also have new plug/wire pigtails if the wiring plug is corroded bad also.
