Head stud update.
Dirtleg
Cloverdale VA
Do you have an intercooler?
Good luck
At anything over 12 psi you damn sure need an intercooler. I have a melted down, cracked block BMW engine at home to prove it.(bad judgement on my part I know) Intake air temps get too high when compressed much beyond 7 psi. Over about 12 you lose any gain from boost as additional heat. I would recommend an IAT as well as an EGT on any heavily boosted engine.
Joejohn
ok guys I got the studs in may hands and I am trying to post the pics. I just need to upload them and post. Looking good hopefully my buddy can DL the pics for me and you guys can have a looksy.
93turbo_animal
Marengo,Ohio
That depends on your turbo weather 12 psi is out of the turbos map then it will heat the air much more but the 94-97 pSD's stock put out 17-20 psi and no intercooler
So... Did I miss the stud testing psi or what? I'm really interested in how these studs tested out being a cut thread and not a rolled thread. Joejohn??? Any updates coming soon???:dunno
razorback
branson, mo
diesel turbo and gas turbo are two completly different monsters. safest boost level with pump gas (93) is 17-18psi depending on how your motor is tuned. ive seen 90+ psi on "pump" diesels before. (aftermarket twins and lots of other upgraded stuff obviously)
Vincent
