Head Bolts
nelstomlinson
Delta Junction AK
Torque to yield? Is that where one of the two bolt heads twists off when it's tight enough?
The one I just took apart had what looked like standard, 12 point bolts. I had to buy some 12 point sockets. It's been a long time since I got into an engine.
SkipBurney
Statesboro Georgia
The 6.0 and newer 7.3 engines used the torque to yield bolts and were notorious for leaking and blown head gaskets. As soon as my 6.0 F-350 went out of warranty I changed them out for a good set of studs and tossed the egr cooler.
Factory spec is 100 lb/ft. I believe that I've seen people say they've gone to 110 but don't quote me on that. Even though they aren't TTY bolts, they can and do stretch some over time. The best bet is head studs.
chillman88
Central NY
Is that for the 7.3 or the 6.9? I assume they have different torque specs?
Is that spec oiled threads? I know it's supposed to make a difference if the threads are lubricated or dry.
Dane Rickford
Markleeville, California
That’s for the 7.3. And I did mine oiled just for a more accurate reading, but I don’t know if it’s supposed to be done oiled
Macrobb
North Idaho
Remember, it's not boost that blows gaskets, it's the (much) higher pressures from burning that air with more fuel.
So 45 psi and no extra fuel may not blow a gasket, while 10 with extra fuel may.
That being said, I've run a N/A IDI block and bolts at 15 psi, ~250 RWHP for over a year before failure... and I cranked it up *after* I'd overheated the engine and had the gaskets weeping coolant when hot already...
