glow plug issues
erikbala
Ride rank make Bank
Ellensburg/WA
about two weeks ago i installed a manual push button and disabled the controller.
well to day it hasnt been above 10 degrees, and had a really hard time starting, finally got it started, my issue is that the plugs are receiving constant heat not much just for the light to be dim, i disconnected the power to the relay and the push button but plugs are still getting heat what is my problem?
thanks for the help
How did you install the manual button? You have the early system with the glowplug relay on the pass side fender correct?
mabc926
Mojo
Hidden vally
My guess is your glow plug relay is getting ready to take a sh*t on you.
It's probably just stuck half way (half way on, and half way off)
Get a new relay and you should be fine.......If it hasn't fried your glow plugs, I'd suggest unhooking the batteries til you get the relay replaced.
erikbala
Ride rank make Bank
Ellensburg/WA
yes the early system
up in-till now all was fine, not sure why this started today
any how i removed the white wire from the relay and ran a wire to from the same post to the push button and grounded the button
mabc926
Mojo
Hidden vally
White wire? Should be a purple wire....
the ****** part is that the relay is brand new its been in the truck two weeks
Where did you get the relay? I got a relay from Autozone and a week later it fried.
erikbala
Ride rank make Bank
Ellensburg/WA
maybe i do have the 7.3 system
im not sure i have only had the truck over a year
the white wire shown is the one i removed i got the relay from napa
Yes, that's the later system that mounts on the engine near the firewall.
I would check for voltage at the plugs. Just because the dash light might be on dim, doesn't mean the plugs are necessarily getting power.
mabc926
Mojo
Hidden vally
Yeah man, that's the new style controller.
I have no clue how to hookup push buttons to the new style.
erikbala
Ride rank make Bank
Ellensburg/WA
well my multimeter isnt working but i set a test light to a glow plug and it gets a faint glow to it
