Black dawg
have any of you guys measured the voltage that the glow plugs produce while the engine is running?
Wait, what? Glowplugs produce voltage? How does that work?
Jim, how big are those diodes anyways? I can just see 8 fat monsters lined up in packs of four on each side of the intake, lol. You are right tho, more failure points in a pretty simple and reliable system, not really what we're going after...
U2: Well, maybe I'm not understanding what you, LCAM, and 93CC have in mind, but I don't see how a separate set of 8 powered LEDs connected each to a GP would tell you anything other than at least 1 GP is not open. Remember the GPs are wired in parallel, so if even 1 GP has a path to ground, all 8 LEDs would light. (To prevent this you would need 8 diodes in series with the GPs, and these would need to be huge diodes capable of carrying the entire current for its GP).
You can't add diodes, ammeters or anything inline with the original glowplug power circuit, this will affect the current flow of the original circuit and if you are running the original glowplug controller, it won't like that. A diode has .7v forward voltage drop.
