Glow Plug Harness... New
tbrumm
Richland Center, WI
Gary, do you know if this IH harness is exactly the same as the one on our trucks and is "plug and play" without modifications? I thought Ford had their own version of the harness, although the actual glow plug wiring.IP, sensor connections would undoubtedly be the same. I am concerned the IH harness might not just "plug-in" to the rest of the Ford harness. I also see that Uhaul has this harness listed for an E350: http://www.ebay.com/itm/Glow-Plug-Harness-Ford-FOUZ9A451A-1989-90-E350-Truck-7-3-Diesel-1811105C92-/200756642605?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ebe07432d&vxp=mtr Do you know if the harness for the E350 is the same as for the F350? I appreciate any insight yopu may hove on this. The connection on my glow plug harness are brittle and falling apart, as are the connectors to the IP. Thanks! Todd
Jbevs
IDI Newb
IL
One can be built for about half that.
cpdenton
Truck needs paint.
Conway AR
I have wondered if these will work on my 92 model. I plan on adding a turbo as well, would this still work if you had to relocate the gp relay?
G.W BUFFALO
effort, pa
I used this harnes on my truck, not plug and play you need to tke your ford harness apart and wire this glow plug harness in with your ip harness ad such..
tbrumm
Richland Center, WI
Just bumping this thread up to see if anybody knows if the harness for the vans is the same as the trucks? Thanks
Seven4eight
