Dave 001
What is this thing? It has something to do with the fuel level gauge.
And removed (it just snaps in)......
Ford is famous for their stupid idiot oil pressure gauge. Are the temperature gauges also "stupid"? There are two resistors on the circuit membrane. The top 20 ohm resistor is for the idiot oil pressure gauge. What is the bottom resistor for? I can't trace the circuit because the membrane is discolored in that area.
If I remove the clips that secure the membrane to the gauges, can I remove the membrane from the cluster? How do the clips come out? I tried removing one but it was rather tight and I don't want to ruin anything by using force if I am wrong about the clip removal.
Thanks for the help.
