Fuel System & EGT's
1990350idi
Albion, IN
Ok i have turned up my pump 3 flats. Egts max out at about 950 if i stay on it @ 2500-3000rpm. I have very little to no smoke. I dont care much about smoke but i keep reading threads that indicate smoke when the pump was turned up and it made me curious. Could my timing be that far off? Any other ideas?
Hybrid455
Sandia Park/ New Mexico
This might be some of it.
If your in Indiana then you don't have a lot of altitude to deal with and you've got more atmospheric pressure to supply enough air to the combustion chamber and complete the burn of the added fuel.
When I lived in Texas about 800 ft above sea level and had the pump turned up 2 flats it didn't really smoke much under normal conditions. When I moved back to NM and 7000 ft the ol gal would kill some mosquitoes in a hurry. I put a turbo on it and wala, enough air for the burn, very little smoke and lots of power.
How many miles are on your IP? Could just be getting worn out. :dunno
1990350idi
Albion, IN
As for the injection pump i dont really know. I assume it is original and the truck has just over 109,000. What i dont understand is that if the injection pump is going bad why are egt's so high? Wouldnt that indicate it is getting enough fuel?
IH_444
Iowa
It should. I would say your air filter is plugged, since lack of air = higher EGT. But if that were the case it should smoke more.
1990350idi
Albion, IN
Nope, air filter is brand new. no soup bowl and homemade cold air intake. It actually dropped egts 100-200 degrees. :dunno
1990350idi
Albion, IN
Considering its below freezing and i'm not pulling a trailer or anything, yea i think it is a little. By the time summer gets here and i start pulling trailers loaded down with hay that number will increase dramaticly.
dyoung14
Is getting worn out
spencer,tn
Considering its below freezing and i'm not pulling a trailer or anything, yea i think it is a little. By the time summer gets here and i start pulling trailers loaded down with hay that number will increase dramaticly.[/QUOTE/]
i dont think thats hot at all,
