Fuel Seperator Leaking
HammerDown
Glenolden Pa
After 34 years it appears the screw-on water separator is weeping fuel from the electrical
plug sensor.
Anyone know of quality replacement part still available and from where?
Thanks for any feedback.
gandalf
Senior Member
CA &/or Maine
I'd suggest replacing that filter with a one peace filter. You will do away with the potential for leaking. I can't remember the number for the single peace filter, but I'm sure some one will offer it.
JPM4
North Alabama
I can't really see what you're talking about in the picture, but years ago, I had same/similar problem. Replaced o-rings, no issues since then. I'm sure there's videos somewhere on the internet. I seem to remember finding the correct size/type o-rings was the hard part.
Does this help:
or
Oh yes. Now I know that you're talking about the sender in the aluminum sediment bowl for the water in fuel light. Yes you can unscrew that and replace the o-ring on there. It takes a 14mm deep socket or wrench. When you tighten that sender back up, don't overtighten it. It's just made of plastic and will break. Yes that's experience talking.
HammerDown
Glenolden Pa
Yes, I believe that is where the "weeping" is coming from. I wasn't sure 'if' there was an o-ring in there or not.
Question; do you only if there is also an o-ring at the brass water drain valve?
HammerDown
Glenolden Pa
Does this help:
or
I'm referring to the lower screw-on water separator under the fuel filter. Not the top fuel heater.
I don't know about at the drain. I kept that 7.3 filter head when I swapped the 7.3 into my 1985 Blue Truck. I never did use that style of filter. I switched to the one piece filter because the o-ring that seals the sediment bowl to the filter can, sometimes, be a PITA and leak. I would have to look for that sediment bowl or a different one this weekend to be able to answer that question.
HammerDown
Glenolden Pa
Since new I've never had an issue with the large sediment O ring.
If u have a manufacturer and part number for the one piece filter I'll take it.
I've used a Hastings FF1039-SP. I forget what brand I'm running right now. That one does have the place for the sensor.
