ghunt
I recently installed a fuel pressure gauge between my lift pump and filter head, and apparently I have a weak pump because I'm only seeing 1.5 psi at idle on the gauge.
At the moment I am contemplating going to an electric pump (like a Carter P4070), since it would make bleeding the system easier and such. Of course, it would be cheaper to just replace the mechanical pump, although the only pump I can find at local parts stores is an Airtex (probably chinese) which I don't put a lot of faith in.
Opinions?
Opinions?
