fuel prefilter
grumpy1
AA
i think this filter has a lot of surface area and would be a good filter before the electric fuel pump
i'll be danged if i can find the right canister for it
any info appreciated
Farmer Rock
Glen Rock,PA
I assume you are talking about the big primary fuel filter mounted on the passenger side of the engine? napa has them.
Rock
Farmer Rock
Glen Rock,PA
I honestly think you will be better off with getting a spin on filter assembly. The spin on filters are a lot easier to come by, not as messy, and probably filter much better. JMHO
Rock
gnathv
Athens, Al
This is what I use, just need a filter head.
gnathv
Athens, Al
On my frame rail, after the FSV and before electric pump.
Mine is a powerstroke, but you can do IDI the same way. I have a second fuel filter after the pump.
gnathv
Athens, Al
I use that model filter because it’s about 5 inches tall, frame rail protects it.
Cubey
Van dweller
These are a good option:
https://ph.parker.com/us/en/diesel-fuel-filter-spin-on/120at
That lets you delete your factory W/S too, if you want to do so. My RV's W/S was gone when I got it, so I put a Racor head I pulled off a junk yard IDI years ago in the same spot as the factory W/S... which is how I found it on the salvage pickup it was on.
I have it installed after the Holley Red fuel e-pump (mech lift pump deleted) so my system is like this:
[tank]-[e-pump]-[Racor W/S filter]-[stock fuel filter]-[IP]
I need to go put back the pre-filter before the e-pump. I removed it when I was diagnosing fuel pressure related timing issues. It's a cleanable/replaceable element one and it was leaky, so I might put a solid metal one and just replace it once it once a year since I can't see inside. It's too far from the Racor to bother running hoses back and worth, or I'd do that.
gnathv
Athens, Al
I had one similar to yours on my truck and one day something shattered the plastic or nylon bowl on it, that’s why I changed to filter style with pet **** for drain.
Lance
