Fuel Mileage
motoneil
ogden,ut
I just replaced the IP with a new Uhaul pump and 8 brand new BB injectors. The IP is static timed with the hash marks lined up. The fuel mileage is horrible, worse than before when I had a leaking IP pump. Any suggestions?
forcefed
Newark, OH
is the truck smoking at all at idle. Sounds like said above, timing is off still.
It would appear your timing is retarded then. In lue of finding some one with a meter, or an expererienced ear, you could advance it until you find that under hard acceleration, you are getting black smoke. However, there is no substitute for a proper timing job, and advancing it too far will hurt economy and will damage your glow plugs.
bigblue85
Vallonia/IN/USA
is it possible for an idi to sorta come out of timing itself? kinda like how a chain ran timing system can jump timing? although ours are gears??
gatorman21218
Ashland VA
yes but over a long period of time. As the IP wears it retards, but we are talking 10s of thousands of miles before you notice it. also fuel pressure from the lift pump can change the timing.
HammerDown
Glenolden Pa
Can't see that happening with 'gears' a wore timing chain with a lot of slack can jump a tooth.
As with my timing I would bet, with normal wear on the two gears there is some end-play > thus causing a slightly retarded situation. when (I) installed my Baby Moose which was(my original IP-rebuilt by Mels man) I lined up the scribe marks. Over a year later I finally had Mel properly time it and it was retarded 4-degrees!
Can't say if MPG improved yet but, it leaves the hole a little better.
