front axle problem.
The timken can be purchased separately. Ford dealers only sell the whole spindle unit $450. Don't know what the bearing # is, but had the pass side replaced in Fargo ND $236 + $155 labor. Bearing # race and cone has the number on them after you get them out, maybe just the nut has backed off.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I'll see if I can find yo a part number on this. But that is ALSO a VERY real possibility.
I was told by a mechanic once that a loose nut can be a cause of premature wheel bearing failure. This may be true, I just thought i'd share.
TIMKEN Part # B2110 and NATIONAL Part # B2110 are the bearing only for a 1999 F250 SD. Part numbers are the same for an F350 SD as well. No sel numbers however.
wanabebig
Anthony, ks
hey thanks for all the replys. and yes goofy you are correct on that number, i went and got that lil bearing yesterdayafternoon. the truck is coming back to my house today and then it'll get pulled part and fixed, thanks again for the help tho.
