Front Axle Code
jaed_43725
Need Quad Cab 4x4
Lillington/NC
I have an 88' F-250 regular cab, regular bed, auto 4WD with the 7.3. I need to replace the ball joints, and have found that the top ones are the across the board. However there were 3 different bottoms made. I am going to be getting Mevotechs. I have the info off the tag if someone could tell me what it is so I can order the right ones (V810 311 10 S). Any info would help. The Mevotech part numbers for the 2 that may work for my app are MK8435 (4,600lb) and MK8195T (3,850lb). Thanks Jake.
tractorman86
Buckeye, AZ
the tag in the drivers door will tell you the GVW of the front axle, one of them will match one of those part numbers
Dsl_Dog_Treat
Decatur,MI
Easy check is big hubs or little hubs for the lockouts.
The smaller hubs are for the D44 axle(lighter GVW) and the larger ones are for the D50 axle (heavier GVW).
