metalminded
I believe her truck is a 92 or 94 idi NA crew cab 4x4 automatic.
Was towing a trailer when it started puking tranny fluid. Fluid was said to be coming from the starter out of the bell housing. From my reading, it seems like there is a tendency for the front seals in the automatics to leak when hot? Any other common issues that might show this symptom? I assume the transmission must be dropped to replace the seal, and perhaps an aftermarket cooler added to the system? If the transmission must be dropped, what else should be addressed/checked while its out? There is a good likelihood that i will be driving up(3hrs away) to do the work at her farm. aside from the usual wrenches, sockets and impacts what else would you suggest i have on hand? might go look at a tranny jack at harbor freight....
thanks
thanks
