Well this is GREAT NEWS... Now we wont be taking things apart once again. Thats a sure way to wear out wrenches and threads. Nothing worse that a tool with a loose fit....
So in closing this down finally it has come down you you trusting a couple of shops to tell you things were ok when they clearly were not. Macine shop "missed" the oem weak valve springs so piston valve contact happened causing much trouble and sinking valves way more than they should have been. All due to weak springs.. Well not is well taken here. Now an injector was not correct after you had a shop test them. Sadly this tells me I need to be doing more work for others. Or at least recommending 2 other members of this great forum to inspect injectors. But in the end all is well and you have a nice rig with a powerful engine to enjoy finally. This entire post reminds me of wanting something so bad I could taste it. Makes for a good feeling when you finally get what you wanted....You truly earned this good news....
