flareside_thun
Reviving The General Tao
So, let me get this straight...what exactly is WMO?I'm assuming something with biodiesel?
Do you havepower to the pump while cranking? I have had good luck with my Holley red so far and have been running 40% waste hydraulic oil. I am also useing 1/2" plastic air brake line for my fuel line.Do you guys have any fuel presure monitoring instrumentation aboard? Now that colder weather is coming, I'm thinking of adding something at the IP. I'm a little perplexed at this issue, as my basic holley red with the factory fuel filter in-line after the pump seems to work just fine.My biggest problem is hard starts on cold mornings - it fires up, then dies, and it's not air. I think it just runs out of fuel inside the IP. Takes a good bit of cranking to get it going again. That's why I want to monitor the fuel presure.
thanks for the tip on aluminum, guess i thought it was allot more. i will get this system set up right yet.
