pybyr
My 1989 never had any sort of radio in it, and so never had an antenna, either.
I got an antenna assembly, and when I look through the antenna mounting hold in the passenger side front fender, I can see a plastic knockout plug-- which I assume has to come out in order for the antenna cable to feed through.
I am sure I could blunder my way through the antenna install and figure it out as I go, but since it's getting cold fast here, and short daylight, can someone or several of you please give be a bit of a step-by-step [things like: do I remove that plastic plug entirely, or just punch/ drill a coaxial-cable sized hole through it; tips on how/ where to snake the coax cable down through/ under/ across behind dashboard, etc.)
Thanks
Trevor
Thanks
Trevor
