flywheel question.
BigDiesel
Canada BC
The balancing on the stroker flywheel might be different to an IDI flywheel. The gear roll over noise isn't that bad on a SMF, I just did a 5 speed swap and put a 6.9 flywheel, pressure plate, and 7.3 sprung clutch disk. The noise is only noticeable at idle, and when lugging below 1200. I lowered my idle to 500-550 and it has seemed to lower the noise, if I were to rev it back up to 650 the noise increases half again. Hope this helps.
