FiredudeL4
Hey guys hope this finds all well and trucks running good, now as for mine its running fine , however I have noticed the last few mornings when going to work that the temp gauage (idot gauage) has really been fluxuating up and down its about a 45-50 min. drive for me and 90% is freeway with the cruse set at 70 the needle will move (sometimes I see it moveing) between the "C" and that first line of the "NORMAL" range now the trans temp gauage is staying right about 125 (if that helps any) this afternoon comeing down the same freeway same speed just midafternoon and alittle warmer it seemed to run between that same first little line and the "N in the NORMAL" any ideas? just for reference the temp sending unit is almost new it was put in back in November, thanks
stay safe out there
Roy :draw
stay safe out there
Roy :draw
