Flip out bed steps for easy access?
carid
Supporting Vendor
NJ, Cranbury
Additional step for your truck's bed is always a plus. If you need to hop and get something really quick from the bed or a tool box a little side mounted flip out step will perfectly do the job.
These static and retractable steps will be perfect for lifted trucks and work trucks.
Here at CARiD we have a wide selection of bed side mounted and rear mounted steps that will definitely make your life easier.
# 1 AMP Research® - BedStep2™ Side Step
- Mounts on either side of the truck bed to the vehicle frame with a small amount of drilling
- Large step pad supports 300 pounds and is large enough for two full-size work boots
# 2 AMP Research® - BedStep™ Bumper Step
- Does not require a trailer hitch because it mounts to vehicle frame member underneath rear bumper
- Large step pad supports 300 pounds and is large enough for two full-size workboots
# 3 CARR® - Polished Tool Box Flip Step 10
- Sways back and forth and securely locks in both positions (swiveled up and folded down)
- Offered in 3 sizzling finishes: Titanium Silver, Black, and Polished
# 4 CARR® - Work Truck Step (slide in and out)
-Tough aluminum construction with interior steel straps for additional strength
- Able to withstand up to 500 lbs of weight
- Can be either in the open or tucked away position
- When in the out position – provides a solid non-skid step surface for both feet
- Fits industrial, commercial, utility, service, and fire prevention trucks only
Check out how it works on this YouTube video: https://www.youtube.com/watch?v=RaPeH961_Tk
There's also a huge selection of other helpful bed accessories and parts on CARiD, check them all here.
Which one of those 4 would you choose for your truck?
# 1 AMP Research® - Bed Side Step
# 2 AMP Research® - Bumper Step
Let me know which ones do you like and I will calculate the quote for you!
(Just don't forget to include your Make/model/year, zip and email)
Discounts are available for forum members!
carid
Supporting Vendor
NJ, Cranbury
If the side steps we've listed above wasn't your cup of tea, Bully has something extra for you! This brand is famous for its quality, so you can forget about the replacement for a long time.
All Bully products are engineered and crafted from the sturdiest materials to ensure years of reliable and trouble-free service. Their products are guaranteed to meet the highest quality standards and be free from any defects in materials and workmanship. More abour this brand here: Bully | Chrome & Stainless Steel Accessories - CARiD.com
They offer 2 different styles of side steps - Flip Out Truck Bed and Truck Bed Side Steps.
Bully® - Flip Out Truck Bed Side Step
- Custom-crafted for a perfect fit on your vehicle
- Mounts solid onto truck bed sub frame
- Installs on both driver and passenger side of truck bed
- Side step supports up to 300 lbs
- Comes with all necessary hardware.
Bully® - Truck Bed Side Steps
- Made from premium materials to endure years of abuse
- Includes everything needed to get the job done
- Arrives to your home well-packaged and in no time
- Backed by a solid 1-year warranty.
Which ones do you like?
carid
Supporting Vendor
NJ, Cranbury
All PM replied!
The steps are good in stock, so if you need any product specs or simply want to get a quote - just let me know or send a PM!
Lance
Staff online
